rickduff
Hey All
I have had the TRX 2 for about 3 years. It is used in the home setting with a outdoor antenna. There seems to be an issue with the antenna connection on the unit itself.
Sometimes if the scanner is moved at all, say for dusting the scanner looses the antenna connection. The cable stays connected but I have to fiddle around with the cable to find just the right place for the connection to work again. I have cut the cable back 1-2 feet, doesn't make a difference which makes me think its something with the connection on the scanner itself.
Anyone else notice this or have this problem?
Thank you
Thank you
