Antenna Connector
homerjay
Beamsville, Onatrio
Hello all, apologies if this is in the wrong area. I'm looking for a connector to split my F150 antenna to the factory radio and a bnc connector. If any such itme exits could anyone point me in the right direction to look. Thanks
prcguy
You may not be able to split the signal off the antenna to effectively feed another type of radio and you might need a diplexer. The Y connector cables are usually made to combine two antennas to the car radio. A diplexer will let the AM/FM signals pass on to the car radio mostly unaffected then the diplexer will send VHF/UHF signals to a scanner or other type of receiver without affecting AM/FM reception. If this is your need then here is one version but I don't know how well it works. T64 - AM/FM to Scanner Splitter
And of course its discontinued.
sallen07
Rochester, NY
BNC connector for? Scanner?
Keep in mind that an unpowered splitter will give each side 1/2 of the signal. And make sure you do not transmit into that BNC or you'll probably fry your factory radio ....
prcguy
In this situation its worse, the AM/FM antenna is really high impedance in the AM broadcast band (a couple thousand ohms) and it uses a high impedance coax. The AM receiver is very sensitive to any changes in its antenna so you can't simply add a 50 ohm splitter as that will load down the high impedance side and really degrade AM reception. A proper diplexer will not affect things much.
