Antenna for Anytone 868
W2SJW
Senior Member
Moderator
Northwest NJ
#2
If you want a compact antenna - https://powerwerx.com/tera-ant-54-compact-dual-band-antenna
If you want a full-length antenna - https://powerwerx.com/tera-ant50-dual-band-antenna
I use the ANT-54 on mine with no issues at all. These have thread protection all the way down the length of the center pin. This is a MAJOR consideration, as not all SMA-F antennas will fully protect the pin (and lead to all kinds of strange behavior due to RF ingress).
If you want a stubby for hotspot usage, this is also great - https://www.amazon.com/Retech-RHA-6...00DSEINAE/ref=cm_cr_arp_d_product_top?ie=UTF8
W2SJW
Senior Member
Moderator
Northwest NJ
#4
It's not meant to be an improvement, it's made to take up less space.
I use the 868 as a backup to my 7550e on my hotspot, and my county public safety is all on VHF analog repeaters. It works perfectly for what it's intended for (basically, a nightstand radio & fairly unobtrusive to the eye with the smaller antenna).
W2SJW
Senior Member
Moderator
Northwest NJ
#7
There are 100x more available choices for a standard SMA, you just need to look around a bit on eBay and Amazon.
For the OP - yes, a mag mount on the roof will be heads-above the rubber duck in performance, but you also need an appropriate adapter. Don't cheap out on that part of the project.
#8
any chance you can point me in the right direction as far as adapters and antenna go?
W2SJW
Senior Member
Moderator
Northwest NJ
#9
I can't be any help on the adapter, but my favorite antenna hands-down is the Diamond NR-770HA.
It doesn't require a ground plane at all, so would work pretty good on a large mag mount.
