Diamond:what dedicated airband antennas are you all using on handhelds? i am not sure if i am better off getting a dedicated airband transceiver to RX, or try different antennas on my bcd436 and yaesu amateur radio.
Bearcatrp- A Bearcat BC125AT is great on aircraft band. Private message me for information buddy and I use a Diamond RH77CA antenna as a option. The supplied antenna is a waste, don't bother using it.Have a comet tri band sma3 on my 436. Picks up air pretty good. Am currently researching dedicated receivers for air band though. Either Uniden 125AT, 330T, or spend the bucks on a Icom R30.
Comet Tri-Band HT Antennas SMA-3
Already purchased the Icom R30 so looking at a options for an indoor antenna. May get the Diamond R220-D until spring comes, the get a bigger discone.Bearcatrp- A Bearcat BC125AT is great on aircraft band. Private message me for information buddy and I use a Diamond RH77CA antenna as a option. The supplied antenna is a waste, don't bother using it.
Thanks. Hate it when a online store does show back ordered until you purchase. Universal radio tells me 1 march now. I have an old floor lamp I’m going to attach it to. Hope to get it close to the ceiling. One I get a full discone up in spring, then will use the 220 for my camping trips. How are you liking your DV-1?
Diamond RH77CA,(Purchase it with SMA connector) don't use ANYTHING else! This antenna has been around since the 90's and is great all the way around on my Uniden Bearcat BC-125AT. Hope this helps you Trauts14!what dedicated airband antennas are you all using on handhelds? i am not sure if i am better off getting a dedicated airband transceiver to RX, or try different antennas on my bcd436 and yaesu amateur radio.
Buy Diamond from Amazon.comDiamond takes FOREVER to ship back orders! It's not Universal Radio's fault. Try HRO:
Ham Radio Outlet Search Results
