APX Antenna help
devicelab
Whacker Extraordinaire
Nowhere in WA
Anyone know which Motorola antenna this is? It looks like an early version of the NAF5085A but it's def not that antenna. The one in the picture has a slim upper part and is longer. I believe the radio is the APX 8000.
I would speculate an early high-gain 800 meg model..?
nokones
Sun City West, AZ
Are the APX antennae color-coded like they use to be for the JEDI & Astro 25 Series portables?
KG4INW
Midlothian, VA
I don't believe so, the insulator is the same color on all models that I've worked with (except the all band antenna has blue) but the outer jackets are usually labeled with frequency band or even part number now.
KG4INW
Midlothian, VA
I made a correction to my post, if someone else has information refuting that, I'm all ears but I've not seen the same color coding like they used to use.
devicelab
Nowhere in WA
Update. I received the PMAF4040B today and after doing a quick analysis, I thought I'd share the feedback compared to the NAF5085A.
Here's the old-school Motorola 800 GREEN:
dickie757
Wired
Out of range
Also...
NAD6563A
VHF only
Red dielectric, no other indications of model/bandwidth
Works very well on 7k, 8k VHF only.
