Hi guys,
All things considered I don't know why you got all hyped up over an event lasting a few seconds and went after it without a plan, without rhyme or reason. Be that as it may this has turned into an antenna discussion without anyone asking the question of what sort of a receiver having a 300 ohm impedance would be used and for what. In the end the poor guy was left twisting in the wind.
"Ok Right I have that, I am building a yagi, how do I tell which its going to be, what are the design differences?"
Chad, you have a lot to learn and it's far more than can be acomplished here. Being you're a ham you must have heard of the ARRL. I don't want to sound sarcastic but by the looks of it you all are in way over your heads so start cracking the books before you go crazy wondering why that contraption doesn't work as you expected. Here are a few examples.
"Most TV antennas are Log Periodic, not Yagis."
I'll disagree, they vary widely and actually only a few are logs. Some ARE Yagis, they're high gain deep fringe single channel VHF or UHF antennas. BTW, I once had boxes full of them for channel 68 and wish I had them now, just look up the frequency chart. Don't argue, I didn't spend all those years in the business for nothing. Actually I did it for the money.
"It depends on the driven element."
Sometimes.
"Yagis driven by simple dipole elements are usually 50 ohms."
A dipole is 75 ohms which is why those TV Yagis came with short RG-6U jumpers and F connectors. A 50 ohm Yagi has a gamma matched electrically continuous grounded driven element while one for 75 ohms has one split, center fed and insulated from the boom.
"I'm also homebrewing a yagi antenna, for 800mhz...I want my yagi to run at 50Ohm. I guess 200 is possible, I picked up a 4:1 balun while I got the 9913. It's nice to live 30 min from HRO in Woodbridge."
You started off on the right foot, then you tripped over it. If you want 50 ohms, MiniNEC for 50 ohms. OK, 200 is possible but totally impractical, then you bought the wrong balun. I know of no baluns for 800MHz besides TV baluns and they're 4:1 but then HRO sells HF baluns and they get flaky above 30MHz.
"If I fiddle with the fed dipole length I can get the ohms to be 50, but for some reason I think I'm doing something wrong."
You're doing a LOT wrong, feedpoint impedance is affected by a lot more than the length of the driven element and that determines the resonant frquency more than anything else. It's the feedpoint >along< it that determines the impedance more than it's overall length. Dr. Smith says "Oh the math, the MATH!" No, I'm not Lost In Space, I'm talking about the Smith chart. There are other things to consider like the ratio of it's length to the reflector and first director, element spacing and more. Then there is beamwidth, forward gain, front to back and front to side ratios, the whole polar pattern is affected by these factors.
Al, stick to antennas, you can't read a map with an interpreter. (;->) You have US-1 and Woodbridge right but neither Johnny nor HRO are in New Jersey. Now rather than going through all that 50-JO stuff why didn't you suggest a loop Yagi? Heck, a bunch of cut up beer cans on a broomstick may look like some sort of sci-fi Bazooka but it works. And no, that wasn't a typo. (;->)
Now is when I really wish I still had that box of antennas. I could offer them free of charge, just come and pick one up. Here's your antenna >>>WHACK<<< an' thet's fer gittin' so gol durn tek nee kull on me! Consider the herringbone welt you get from the antenna over your head the KB2VXA brand, the mark of quality, so wear it with pride. (;->)
