So, from the pictures, the problem is now obvious. My question is:
Will the solution be as simple as a 14' relocation.
The antenna on the left is an A99 10-11 meter antenna.
The antenna on the right is my Ed Fong for GMRS
Each antenna is causing interference with the other. I had the Ed Fong
just leaning against the shed on a pc. of mast with RG-59. I moved it
to where it is in the picture and changed the cable to LMR-400. My SWR
got worse! If I move the Ed Fong to the front of the shed then they will
be separated by 14'. Will this fix my interference problem? And, will it possibly
lower my SWR below 2:1?
