antenna laws in the Toronto area?
N
nec208
Guest
#1
What are the antenna laws in the Toronto area?It looks like I'm going to be moving into a apartment and cannot pay rent so have to downside to a apartment .
I was thinking of getting some 800 MHz antenna that is mounted by the window .And take the antenna to other room if needed.It will have to be later on , has I drop my scanner this week on the ground and it does not work in a proper way.
I need a new scanner and will get a better 800 MHz antenna than the cheap one that comes with it .And because all I need is a 800 MHz antenna that is 90% of my monitoring.
Hamilton, ON
#3
Then get an 800 MHz antenna and put it inside your apartment. If you mount it to your balcony your building manager may request it be taken down.
N
nec208
Guest
#4
sorry I'm asking about a 800 MHz antenna mount ..some thing like this
Or a rip one that can mount by a window.
EJB
Downtown Hamilton
#5
Well I know that my building asked that we not put up a sat dish directly on the railing but on a tri-pod.
Best bet-Ask when you look at the place or if you are gonna do it regardless read thru your lease. There are always great nuggets of info there, restrictions.
