Antenna Lead Out..
btritch
Paragould/Greene County AR
Is it possible for me to split off to two scanners where the lead out comes off the antenna by putting two lead out's off the antenna or should I invest in a splitter to split them off? I'm currently using a cable TV splitter and my scanners are interfereing with each other badly..I have ordered some LMR 400 cable, How do I hook it to the lead out? Adapter from RS?
Thanks For The Help In Advance!
Raven95150
Nowthen, MN
I think this has been discussed many times in the antenna forum. (where this question should be as well) A quick search in that forum should give you several answers.
n4yek
Newport, Tennessee
Go to the 'Antenna forum' and do a search with this wording: one antenna multiple scanners
This will give you many threads on this.
