i am scanning the federal government frequencies 163.00 to 174.00 what is the length of my antenna should be at? I have it fully extended at 20 ft.
20 ft, I have a tram outdoor antenna attached to a home patrol 2 radio
If your antenna is a telescoping one, you can use this
frequency formula:
468\frequency in MHz x12 to convert to inches
example: for 168.5 (halfway between 163 and 174 MHz)
468\168.5 = 2.777448071216617
Times 12 = 33.32937685459941 inches for a half wave antenna.
Divide 33.32937685459941 by 2 to get a 1/4 wave antenna length.
33.32937685459941 \ 2 = 16.6646884272997 inches.
round it up , it would be 16 and 11/16 inches.
hope this helps!
No problem, just went off of We the OP referenced at the beginning of the thread. It’s receive only, so 16 or 17 inches should be fine.
it 50 ft off the ground n extended about 20 ft in the air also using lmr 240 coaxAlso I forgot to mention, if you have your antenna up at 20 feet outside this is a very good thing.
One of the first rules of antennas is: “height is might”
73
I just pictured someone with a 20 foot antenna on top of a portable when I read this and had a chuckle..look out for power lines 😅i am scanning the federal government frequencies 163.00 to 174.00 what is the length of my antenna should be at? I have it fully extended at 20 ft.
