ClemsonSCJ
- Joined
- May 29, 2018
- Messages
- 227
Hey guys, I have a question about antenna mounting. I am a deputy in SC and have recently moved to a division where we have “cold cars” (undercover) and we wear plain clothes. I say that, but they’re more like “lukewarm” cars cause they took old road cars and just unmarked them, so the antennas are still on the trunk body making it a dead giveaway. The antennas are those small round barrel looking ones. I moved mine to a metal panel inside the trunk and just plugged the hole with a grommet. With the antenna being in the trunk I get a lot of static now when I get to the outer edges of the county. I don’t want to move it back outside cause it defeats the purpose of having an unmarked car when you have the obvious police antennas on the outside of the trunk.
The solution that I’ve thought about is if I could mount them to that cloth deck behind the back seat inside the back windshield. That way they won’t be inside the metal box like they are in the trunk, but they’ll be hidden by the tinted back windshield. Does this sound like it will work? The only concern I have is grounding. I know nothing about this type of antenna and what type of ground it needs. That should be an easy solution if that is the only issue, cause I could just run a wire to the mounting base from ground and that will solve that. What do you guys think?
