Antenna Replacement
tekrsq
I have several Motorola MT351r's and MS350r's that we use for various outdoor activities. The rubber antenna's on a few have broken. Otherwise the radios are fine. I've tried everything I can find to glue them back together, but it only holds for a little while. Is there anywhere to find the replacement antenna rubber sheaths ? I'd even be happy just finding a few junk radios for parts as long as the antennas were good.
KD8DVR
Columbus, Ohio
Getting a replacement will be hard. FCC rules don't allow for a removable antenna, so replacement may be difficult, without knowledge of radio repair.
tekrsq
Yeah, I get that, but I'm not looking to actually replace the antenna. The outer rubber covering that slides over the antenna wire is what I need. Once you split the radio, it simply slides off the antenna, and another can be put on.
lmrtek
if nothing else can be found, try some heat shrink tubing
jeepsandradios
East of the Mississippi
You may be abll to find a part number and order the sleve from Motorola. May be a challenge but I have ordered other odd parts only that others said you could not get. The trick is finding a true service repair manual on the radio.
tekrsq
Funny you guys should mention the heat shrink. I had never thought about it, but a friend said the same thing the other day. I super glued the sleeve again, and put heat shrink around it. It seems to be very strong. Hopefully it'll hold. In fact, I think I'm going to put a piece of heat shrink around the rest of the antennas as an extra level of protection. I've got 10 of these radios.
Does anybody know where to get a service manual or parts manual for these radios ? I'm just getting the run around from Motorola.
THANKS for all the info guys !!!!!
