Airdorn
Can anyone suggest a low-cost, decent antenna rotator? I just want to use it to turn a yagi hooked to a scanner.
Thanks!
Thanks!
Airdorn said:
Airdorn said:
Airdorn said:Is it special wire, or can't I just use some typical 4-conductor stranded wire for it?
I thought they quit making those antenna rotators, I remember having on the TV when I first moved down to Louisiana. And that was over 40 years ago. By the way, I had the opportunity to go to Frys there in Fort Worth, several years ago and was blown away at allandrewccm said:For the record, I was over at Frys yesterday and saw several of these CM rotors available.
andrewccm said:I am interested as well.. Plan on placing a Yagi in my attic
delta_p said:Does anyone know if this CM 9521A rotator will take attic temperatures ok without failing? Thinking about using one in my attic. My attic gets like nuclear hot in summer
PP
Airdorn said:
