Antenna setup without ground
dragon48
Boynton Beach, Florida
I starting to have fund with some homemade radio (AM and Shortwave) projects. It's quite annoying to have to run a long wire to a cold water pipe or other suitable ground. I'd like to brew some kind of homemade setup that doesn't require an antenna ground.
Modern transistor A.M./F.M./Shortwave radios work with one telescoping antenna and don't require an annoying ground run. With my home-brew, how can I replicate a circuit or antenna setup that will not require a ground?
majoco
Stirrer
New Zealand
J-Pole requires no ground - initially invented/designed to be used on airships (Zepp antenna) and now refined (?) to be made from copper pipe for VHF and mounted on an insulated mast. see here...
Google for G2BCX Slim Jim Antenna.
kb6hlm
All antennas require some type of ground or counterpoise yes even a modern radio and to prove my point attach a ground to that modern radio and you will see what I mean :)
Think about it like this ....A flash light works fine without a reflector but a lot better with one right?? remember the old rabit ears for TVs it has two sides but if you break one off it still works but not as well
It your interested in a homebrew antenna for shortwave there are lots of antennas to build without requiring a earth ground the J-Pole is one of those exceptions witch works quite well and provides a small gain over a quarter-wave ground-plane antenna however its quite large for HF and may not suit your needs
With most antennas you will still need to have some type of ground radials or counterpoise without using a earth ground otherwise you got a flashlight without the reflector:)
You could try using a artificial ground however you would still need some type of ground wire or maybe a steal fence
To give you one example of how important a ground is even to that "modern radio" my father in law gave me his new grundig radio because it had very poor receive and all I did was hook my backyard ground rod to it and it came alive ! even I was surprised LOL .....anyway I felt bad and gave it back to him as there was nothing wrong with it its just that we have very bad band conditions right now and its the worse!
Not sure what kind of antenna your planing on ? the best antenna that I have made that dose not require a good earth ground is the (double bazooka) and is excellent for SWL the one I use for 5Mhz and lower is 120 feet long ! that may not be the right choice for you however :):)
prcguy
Most antennas don't require an earth ground to operate. A center fed or offset center fed is one type and for SW listening, a broad band end fed using a 9:1 or similar balun for matching and a choke balun in the feedline will also operate independent of an earth ground connection. For specific frequencies, a half wave resonant end fed using a 49:1 to 60:1 matching transformer and choke balun in the feedline also works great. For verticals you generally want a counterpoise or radial system, but that is different than an earth ground or connecting to a water pipe, etc.
With any antenna outdoors, the National Electrical Code will require you to ground the antenna or feedline for human safety and this has nothing to do with antenna operation or performance.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I'm surprised no one recommended a loop. Loops don't require a ground and are quite good in rejecting many noise sources. We have many commercial and some homebrew loops detailed and linked in our wiki, viz.
https://wiki.radioreference.com/index.php/Loops
and the SWLing.com blog had an interesting passive loop here - only works on HF, not MW, altho there are many MW designs, too...
New indoor passive loop antenna for shortwave
If you're stuck with indoor antennas or restricted space, loops are a great choice....Mike
prcguy
Yes, especially the W6LVP loop.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The OP didn't say in his/her message what radio was being used...
As the OP lists his/her location as NY, NY - if you are actually in the City, an amplified loop like the W6LVP might not necessarily be the best choice, especially if s/he is using a portable. You would need a pretty decent front end - even with extra filtering, something that LVP does do - to resist the multitude of MW, FM, TV, VHF and UHF stuff that could get in. A passive loop is probably a much better bet. It's selectivity is very tight - so much so that you need to tune it every so often. But that tight selectivity is going to be helpful in rejecting anything else not in its passband.
Mike
kb6hlm
prcguy
Don't think you read all of my posts
You seem like you just want to prove yourself right on everything I say and its getting weird :mad:
Read Entire post before you reply to someone !
kb6hlm
EDIT
You seem like you just want to prove me wrong on everything I say and its getting weird :mad:
If you have a hard time understanding me that's fine just ask I'm all ears but trying to prove me wrong is not productive :)
73s
prcguy
I will admit I probably didn't read all of your posts. If I missed something in your other posts relevant to your post #3 in this thread I'm sorry. I went back and read post #3 in this thread several times and you did give a couple of examples of antennas that require no ground, which I missed.
My comments were mainly from your statements "All antennas require some type of ground or counterpoise" and "With most antennas you will still need to have some type of ground radials or counterpoise without using a earth ground otherwise you got a flashlight without the reflector", which I don't agree with. Hope that is not too weird.
prcguy
kb6hlm
Guess you missed that one LOL ......anyway that's fine we will agree to disagree
Not agreeing with me is not what I think is weird its your tying to prove me wrong all the time ! Now that's weird !
I have been working with radios and antennas way before your where even in diapers young man :)
When you get your license please connect me so we can can have a reasonable conversion without all this nonsense
Take care my Friend
KB6HLM
prcguy
From your callsign we can see when you were born, so when you were about 2yrs old I had built my first 5 tube SW receiver from scratch and was getting pretty good at repairing tube hi-fi equipment for friends. When you were 8 yrs old I had a job at the largest CB manufacturing company on the planet repairing radios. Not trying to prove you wrong, just stating facts.
To keep the thread a little on track, I was asking the same questions as the OP in the mid 60s a few years before you were born and fortunately the FCC engineer in charge of the western states lived next door and mentored me a bit on outside antennas to replace the telescopic whip on our Zenith Trans Oceanic SW receiver. His recommendation was a center fed dipole with a twisted pair feedline back to the radio and it worked real nice and didn't need any ground to make it work.
Take care my Friend
KB6HLM
kb6hlm
Ok you just lost me at "CB manufacturing " LMAO:):):):):):):):):):)
I may have been wrong about your age however ............. well I'll just leave it at that :)
That's it I'm out!
lmrtek
Whether you are electrically connected to ground or not doesn't matter in the world of low frequency rf.
Like it or not EVERY HF antenna you install WILL be using the earth (ground) no matter how hard you try
lmrtek
Why are so many hams self proclaimed experts with fragile Egos?
They may be a Walmart greeter by day yet they get their ham ticket and they all become engineers on forums.
