- Joined
- Nov 5, 2010
- Messages
- 4
I am looking for the old style antenna specialist ground plane type of scanner antenna I believe it had a load coil in the center element does anyone know where I can pick one up at...bands 30-950 mhz
do you have a part # for the larson nmo base, i have a a/s wide band whip with another broken base, seems they dont like the sun.
a/s brand, need to replace what a/s calls the load coil, little black plastic that whip screws to. have founs some, but they are band specific, i have the 25-1300 wideband whip
prcguy, which model number do you have? I am looking for either the trunk mount or magneet mount MON-53(or a number similar to that) How do I contact you toobtain one.
.....I am looking for either the trunk mount or magneet mount MON-53(or a number similar to that).....
For those looking for Antenna Specialists scanner antennas I've compiled a list of the various older models with accompanying pictures. I got my information from the Antenna Specialists 2001 catalog.
MONR31 Base Station (picture 1 from left): "Brings in more stations from 25-800 MHz. Increases scanner reception by as much as 100%. Requires coaxial cable with UHF male (PL-259) to complete installation."
MONR33 Roof Mount (picture 2 from left): "All band (25-50, 130-174 and 450-512 MHz) roof/deck mounting base for permanent installation. Requires 3/8" hole. 17' cable."
MONR51 Magnet Mount (picture 3 from left): "All band (25-50, 130-174 and 450-512 MHz) powerful, heavy duty magnet mount antenna. Center loaded whip. 12' cable and pin plug connector."
MON-52 Mobile Trunk Lid Mount (picture 4 from left): "All-band mobile scanner antenna with enhanced 800 MHz band performance. Exclusive A/S MICRO-CHOKE™ for pinpoint resonance at 800 MHz for maximum range monitoring. No hole, “Quick-Grip”® mount for easy installation. Includes coax cable with installed pin plug."
MON-53 Deck Mount (picture 5 from left): "Deck (flat surface) mounting base for permanent installation. Requires 3/8" hole. 17' cable. Includes exclusive MICRO-CHOKE for pin-point resonance at 800 MHz for maximum range monitoring."
What type of mobile mount would work with the MONR33, it states a 3/8 inch Hole. - Will this screw on any NMO mag-mount / lip-mount?
The later base station versions have the micro choke thingee like the MON-53 but I forget the model #.
prcguy
Oops,, I just looked again, It said MON 31 on the manual. I must have a dozen monitor antennas and just never got a chance to hook this one up.
