Antenna Tower Question
#1
Can anyone identify this tower? I think its somewhere around 30 feet tall when all assembled as each section is about 8 feet long ( 3x8=24ft) plus that center pole which probably adds another 6 feet or so.
Seller wants $150 for it. I'm just looking to put an 8 to 10 foot long (2 meter band) antenna on top.
Any idea who makes it? I'd like to find some specifications.
#2
Looks like a free standing light duty tv tower to me
Doesn't look like it's designed to climb but it's likely light enough to mount on a hinge plate and push it up.
I sure wouldn't recommend using a long mast pipe like the one in the picture.
WTVLCA01DS0
#4
Seller is possibly smoking crack.
A used tower is a big question mark. You never know how the original owner used/abused it. Improper installation could have allowed water to build up inside. Could be rusting out internally. It'd need a really close inspection.
Even then, $150 for a 30 foot tower is high.
30 feet is all you need? Put up a pole.
WTVLCA01DS0
#7
Rohn 25G's have the "Z pattern bracing. That's not a Rohn 25G. 25G's also have two bolt holes on each leg. One 1/4 inch, one 5/16 inch, if I recall correctly.
I did have a tower similar looking to that for an old VHF paging system. I had it removed a few years ago. Never did find any identifiable markings on it.
#9
UPDATE:
Well, I picked up the tower. Paid $100 for it.
Checked inside the tubes and they look brand new. The guy said he bought it new in 2016 and it was only up for 1 year.
Its 30 feet so I should be able to put a nice Diamond antenna at the top of it. I'm also going to mount some LED flood lights up there and a PTZ IP Camera. Its going to be a busy tower!
I'm already 250 feet above the rest of the metro area, all except some hills to the west of me. Getting up an extra 30 feet should help a lot with those hills and getting over some of the brush and trees everywhere else.
Its actually a pretty nice looking tower although it doesn't come with any hardware. I'll have to dig into my box of stainless steel bolts and also weld together a stainless base plate for it.
N5TWB
Sand Springs OK
#10
UPDATE:
There have been many complaints about LED lights and noisy power supplies/transformers. Recommend you check out whatever you're buying for RF suitability before mounting.
#11
Yup, I put up some IP cameras and had to wrap several turns of the CAT5 through ferrites at the camera and the router end to calm down some noise. Plus I always run shielded CAT5 to keep noise out of my radios and radios out of my IP network.
prcguy
