antenna
demloc3
nacogdoches txs
i have pro 106 it has a 800 mhz antenna - not getting stations i know i should . whats the next size antenna should i get ?. ty
You sure the Attenuator is not on and set to global. You try the radio outside and still not picking up signals?
Try the WX bands in your area and see how they come in.
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
What frequencies are the stations on, that you are trying to pick up, which you say you should be able to get? How far away are they?
