Antron 99 swr issue
PJ6
Hi
I hope this is in the right section.
I have an antron 99 but have a swr issue, on the UK cb frequencies, i have a swr of 1.7 on channel 19, 2.7 on channel 40, some people are telling me it is has a pre set swr and you can't adjust it, but there are 2 tuning rings on it which are at the lowest position, i take it i can adjust these to bring the swr down?.
Thanks for any help.
Phill
gewecke
Banned
Illinois
#2
Hi
Phill
1;7 Swr isn't really anything to worry about, but yes you can dink with the tuning rings at the risk of causing a higher swr. Its up to you, but I'd leave it alone. 73, n9zas
#4
Hi
Phill
The UK CB frequencies are slightly above US CB frequencies, but slightly below 10 meter ham! You may have to adjust the A99's length to get optimum SWR.
KB0VWG
Lyford, Texas
#5
If you can mark where you have the rings now and then adjust, but there is no way to adjust the length, just by the rings only.
kb0vwg
wqoi992
gewecke
Banned
Illinois
#8
Hi
Phill
Phil you might try a different vswr bridge as well. Not all are accurate. 73, n9zas
