Problem is, your hardware's just too old. Videocipher II (VC2) is a nearly obsolete analogue system that's rarely, if ever, used these days. There's not a lot of analogue stuff available nowdays, and those who think they can fire up their old NTSC Houston Tracker and just pick up where they left off 15 years ago WILL be disappointed and have a lot of catching up to do. Almost everything these days is either DVBS (scrambled or otherwise) or Digicipher II* (scrambled or otherwise). That said, there is still quite a bit of stuff to be found in the clear on satellites, but you have to have the proper hardware to use it.
I am currently running a Pansat 9200HD (just the base model) DVB/ATSC receiver, 3' fibreglass Channel Master dish somebody on one of the other boards I used to use gave me and a cheap no-name Chinese Ku-only LNB I got off Amazon almost 10 years ago. I don't have my motor any more, thus my dish is currently fixed on Galaxy 19 (mainly so I can get Al-Jazeera and the other foreign services.)
Personally, I wouldn't just rely solely on IC/FTA satellite and only suggest using it as a supplement to your existing ATSC or in-the-clear QAM services, although I know people who do just that. Nine times out of ten you're not going to find your local programming on satellite, unless you're fortunate enough to be in one of the markets that has simulcasts on Galaxy 16.
By the way, if you want feeds you should pay attention to G16 Ku, since there are feeds all over that bird.
So, what you want is:
DVB-S receiver (or preferrably a combination DVB/ATSC/QAM IRD) that can do blind-scan
DVBS2 upgrade if it's available for your receiver, so you can use the in-the-clear HD services like the CW feeds on Galaxy 17 C
DVR (optional, though some of the better receivers, like the Pansat 9200 and the Viewsat Pro, have provisions for this on a "bring-your-own-drive" basis)
DISEQC-compatible dual-band linear LNB that can work with data signals
DISEQC-compatible motor/positioner (which would also be a tremendous help to you, zz, since then you won't have to go outside and reposition it by hand)
If you use Echostar DiSH Net, you might also be able to use your card with your receiver if it has CAM support, since DN use DVB-S with Nagra 3 scrambling, but you might have to reflash the firmware on your receiver to make it work. You'll also need a circular LNB since DBS systems don't use the standard linear polarisation the conventional services do. Forget about trying to receive Direct-TV, XM and Sirius signals on a DVB IRD, since they use proprietary transmission systems that are completely incompatible with anything other than their own hardware (and in the case of the latter two, they operate on frequencies that probably no DVB-S receivers support.)
See also:
http://lyngsat.com/
http://gosatellite.com/ <-- this is who I got my box from
http://global-cm.net/
Hope this helps.
____________________________________________
* Digicipher II is a proprietary system that's completely incompatible with DVB, although ATSC is largely based on it. It includes a scrambling "feature" but not everybody uses it, in fact, there is some stuff in DC2 that does go out in the clear.
