devicelab
Whacker Extraordinaire
Just a shot in the dark but any chance DSD+ could support Motorola Analog Type II in the near future?
Obviously I can't speak to the DSD+ developers proclivities, but I think it unlikely much effort would be put into that. Type II/Smartzone/Astro is old technology and being replaced in many jurisdictions due to the lack of replacement hardware to maintain failing equipment.Just a shot in the dark but any chance DSD+ could support Motorola Analog Type II in the near future?
Unitrunker supports Motorola Analog Type II (but not P25 PII)Just a shot in the dark but any chance DSD+ could support Motorola Analog Type II in the near future?
While not windows based, op25 boatbod multi_rx.py works with Smartzone, both analog and digital. You'll need two RTL dongles, one for control channel and one for voice.
Well this is true to a point but a lot of agencies are sticking with Type II because it works well for them. Digital isn't for everyone.
I'd give TRUNK88-SDR a shot. I still use it for a Type II system (with digital talk groups).
I'm pretty sure it logs everything on the P25 side as far as affiliations, voice grants etc on a Type II system, it just won't decode the digital talkgroups (it doesn't decode anything digital, of course).Unitrunker supports Motorola Analog Type II (but not P25 PII)
Unitrunker directly decodes P25 in the voice decoder? I thought you had to pipe the voice decoder to DSD+ via a virtual audio cable, has that changed recently?Nah it decodes P25 fine but audio support/follow is not implemented for Phase 2 yet. Audio following is flakey anyway -- at least with Airspy.
Unitrunker does that natively for Phase I only. No need for Dsdplus.Unitrunker directly decodes P25 in the voice decoder? I thought you had to pipe the voice decoder to DSD+ via a virtual audio cable, has that changed recently?
Unitrunker v2.x decodes P25 FDMA audio for both 3600 and 9600 systems.Unitrunker directly decodes P25 in the voice decoder? I thought you had to pipe the voice decoder to DSD+ via a virtual audio cable, has that changed recently?
He didn't add TDMA decoding because he respects DVSI's patent on the AMBE+2 vocoder, whereas their patent on the IMBE vocoder expired a few years ago. No mystery to his reasoning.Unitrunker does that natively for Phase I only. No need for Dsdplus.
The developer insists not to develop Phase II voice support due to his own reasons.
Damn I've been running V.2 for a while and didn't even realize thisUnitrunker does that natively for Phase I only. No need for Dsdplus.
Scanners that will follow Type II trunking are cheap and plentiful. I can't think of a reason that I'd tie up my SDR set up following one when I have three scanners sitting on my desk that can do that.
Great example is the New Jersey State Police. It works VERY well!Well this is true to a point but a lot of agencies are sticking with Type II because it works well for them. Digital isn't for everyone.
Except that the NJSP has been issuing out new APX subscribers to all troopers since earlier this year, and has been transitioning them off the SmartZone system and onto the NJICS P25 system. Motorola is building the state a new ASTRO 25 core to eventually replace the old SmartZone system, at which point everything will be P25.Great example is the New Jersey State Police. It works VERY well!
Yes it does, but for op25 to work on Smartzone with a single dongle you have to be able to cover the entire system spectrum within the sample range. Doing that puts considerable load on the host system (for usb data transfer) which is fine if you have a reasonably powerful cpu, but shaky for a RPi4. Given than regular RTL dongles are cheap (~$25/ea) it generally works better to use a pair of them running at 1Mhz rather than one Airspy running at 6Mhz or 10Mhz.Well this is true to a point but a lot of agencies are sticking with Type II because it works well for them. Digital isn't for everyone.
Does OP25 work with Airspy? I only have one RTL dongle. Unitrunker and Trunk88 work OK but DSD+ could be better.
Also my point is that Type II is fairly well-known and should be easy to program. I wouldn't think it'd require a lot of extra know-how.
Sorry for any misunderstanding. When I said "his own reasons" I did not mean that there was any mystery. I meant that other developers do support PII for many years now, as opposed to his reasons not to support it.Unitrunker v2.x decodes P25 FDMA audio for both 3600 and 9600 systems.
