Any difference?
RUSHFAN
Hey guys,
Can anyone give me the real differences between the Grundig S350 and the S350DL? As always,any info
is always appreciated!
Thanks,
RUSH
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Did you Google??
Check the 2 receiver links here...
Discontinued Shortwave Portable Receivers
It looks like the DL added an AGC circuit along with some new cabinet colors - I wouldn't recommend buying either, frankly. Both are single conversion which means that stations will likely be repeated in places you don't expect to find them...Mike
