Any DRM
TigerScan2000
#2
DMR Upstate
Hey,
Here is a link I received from similar post I added to the group back in October.
Digital Frequency Search
Is has a lot of info on DMR Frequencies.
Look for a post with my screen name back in October of this year to read through the post and see other replys.
Hope this helps.
TS
brian
DB Administrator
South Carolina
#3
There's a ton of DMR frequencies around Greenville and Spartanburg. Greenville Trash, Greenville Co Schools and Greenville Health system run DMR systems. Communication Service Center runs UHF and 800MHz DMR systems. Several Greenville Co FDs use DMR channels. And there are lots of other conventional DMR channels in use.
