eng645
How would this antenna work on a Pro-2096 for 800MHZ trunked systems?
800/900 MHz 6 dBi Omnidirectional Antenna
Features
Superior all weather performance
Rugged industrial grade design
Lightweight fiberglass radome
Integral N-Female connector
Heavy-duty steel mounting bracket
Select View: Photo 3D List Price $54.99
Your Price 1-9 $54.99
10-24 $52.79
25-99 $50.59
100-249 $46.74
250-499 $41.24
The HyperGain HGV-906U is a high performance omnidirectional antenna designed for the 800 MHz / 900 MHz ISM band. It is ideally suited for multipoint, Non Line of Sight (NLOS) and mobile applications where high gain and wide coverage is desired. Typical applications include 900MHz Wireless LAN, SCADA, Wireless Video Links and 800 MHz as well as 900MHz Cellular band applications.
This antenna features an integral N-Female bulkhead type connector that mounts through the wall of an equipment enclosure. Included with the HGV-906U is a mast mounting kit. Consisting of a heavy-duty steel bracket and a pair of U-bolts, this kit allows installation on masts up to 2.0" in diameter.
This omni antenna’s construction features a rugged 1.3" diameter white high intensity fiberglass radome for durability and aesthetics. It is designed for all weather operation.
Details
L-com Item # HGV-906U
Manufacturer L-com
UPC # (More) 822335076143
RoHS Status RoHS Compliant (More)
Applications
900MHz ISM Band & Wireless LAN systems
Multipoint applications
GSM
Specifications
Electrical Specifications
Frequency
824 - 960 MHz
Gain
6 dBi
Vertical Beam Width
30 degrees
Impedance
50 Ohm
Max. Input Power
100 Watts
VSWR
< 1.5:1 avg.
Mechanical Specifications
Connector
Integral N-Female
Weight
2.4 lbs. (1.1 Kg)
Length
23.6 in. (600 mm)
Diameter
1.3 in. (33 mm)
Radome Material
White Fiberglass
Mounting
1¼" to 2" dia. mast max.
(31.7mm to 50.8mm dia.)
Polarization
Vertical
Operating Temperature -40° C to 85° C
(-40° F to 185° F)
Rated Wind Velocity
108 MPH
RoHS Compliant
Yes
Wind Loading Data
Wind Speed (MPH) Loading
100 7 lb.
125 11 lb.
Features
10-24 $52.79
25-99 $50.59
100-249 $46.74
250-499 $41.24
Details
Manufacturer L-com
Applications
GSM
Specifications
Frequency
824 - 960 MHz
Gain
6 dBi
Vertical Beam Width
30 degrees
Impedance
50 Ohm
Max. Input Power
100 Watts
VSWR
< 1.5:1 avg.
Connector
Integral N-Female
Weight
2.4 lbs. (1.1 Kg)
Length
23.6 in. (600 mm)
Diameter
1.3 in. (33 mm)
Radome Material
White Fiberglass
Mounting
Polarization
Vertical
(-40° F to 185° F)
Rated Wind Velocity
108 MPH
RoHS Compliant
Yes
Wind Loading Data
100 7 lb.
125 11 lb.
