Anybody else having issues with Hanover Tac
Richmond, Va. (Mechanicsville)
#1
Recently in the past month or so when units go to tac 1 I have to manually go to that channel. It won't scan and pick it up off of ID scanning. I rerote on sentinel but still isn't picking it up unless I go there manually. I did check to see if it had any avoids and there are none. BCD436HP.
Any ideas?
King William, Virginia
#2
Any ideas?
I can second this too and I have the 436 and 536. Tac 4 was the strongest for me and it happen in Doswell I notice what you said tac 1 doesn't come in unless tune to it manually. Hope this is just temporary. It was working good .
