Anyone fancy a theory test?
#5
I got 78 percent: "You have failed :( 39 Correct Answers"
I didn't understand a few things they were talking about: Pelican crossing? Rear fog lights?
jwt873
Woodlands, MB
#6
I managed 82% or 9 wrong... Still failed even though I've driven in countries where you drive on the left and I've seen rear fog lights.
As mentioned above, the hard part is knowing the local non-driving laws like "How long do you have to hold a license before you can instruct someone else".
I did cheat a little and looked up what a pelican crossing was. :)
W9BU
Lead Wiki Manager
Super Moderator
Brownsburg, Indiana
#7
I got an 82 also. As mentioned above, the test is for driving in the U.K., so any of the left vs. right questions are reversed from normal U.S. procedure. But, it was mostly local speed limit and administrative details that tripped me up.
The interesting thing about this is that 82% is a failing grade. If you really have to get something above 82% to pass the U.K. drivers license test, that should give you an idea of how serious they are about driving in the U.K. IMHO, it's way too easy to get a driver's license in the U.S.
#8
I cant believe it says 82% is failing!!!!!!! (As far as I remember 82 is passing -- HELL 70 IS PASSING!)
