jambo said:
My understanding is they are NOT the same.
The Wiki article is wrong.
Motorola refers to it's digital systems (not including TRBO) as Astro.
When they first came out with digital, it was named Astro and used VSELP modulation.
Once APCO picked IMBE as the standard modulation for a P25 system, Motorola began to offer it in their Astro line of radios.
At one point, you could buy the same Astro radio with either vselp or imbe (P25) modulation. The only way you could tell which vocoder was in the radio was to put the radio into test mode and check the dsp firmware revision or read the radio with programming software.
The Peel system which is referred to as Astro Smartzone began life supporting the older vselp modulation format. Recently the system has been changed over to support P25 modulation.
Even today, you can buy a Motorola radio off of Ebay that's Astro capable but you'd better make sure you know which flavour of dsp you're getting or you might be paying to have that radio upgraded to P25.
The part about the Motorola referring to those radios (and systems) as ASTRO25 is wrong as well. Motorola refers to the newer line of radios which began with the XTS5000 and XTL5000 as it's ASTRO25 line. They just use the ASTRO term to refer to the older radios such as the XTS3000 and Astro Spectra.
