anyone know anything about this antanna
PA
#2
"Transmits on 144/440 MHz and is terminated in a UHF connector."
The description is inherently contradictory, which leads the discerning buyer to suspect it is entirely fake, fabricated, and fraudulent.
Québec canada
#3
i m not very good at building antennas was looking for an all band hf to put outside my window i m here 2 weeks for work and one at home i want to keep on dxing here the pixel and windbrook are expensive i just want a good lopp or other antenna
jwt873
Woodlands, MB
#4
As jonwienke points out, it looks like it's just a dual band (144/440) ham antenna. Will it receive down to 500 Khz? Sure it will. But it will be horribly bad :)
It's only 3.5 feet long.. There's really not enough there for decent reception on HF frequencies. But for the Aircraft band (118 Mhz) and up, it will probably be adequate.
Edit.. I just looked again and see the price is $212 dollars US and the shipping is $58 US (For a grand total of $220.00) . That's nuts.. Do not buy this antenna!
eaf1956
Evansville, IN
#5
I agree a small 2m 440 antenna and it is not worth the price.
wtp
Port Charlotte FL
#6
i would say NO
, unless the item is handmade or was packaged by the manufacturer in non-retail packaging, such as an unprinted box or plastic bag.
my first guess is that it would be in a plastic bag. nothing like quality !
New Zealand
#9
I've already got one of those wideband all mode non-directional high power antennas with low VSWR - it's called a dummy load and works really well for about 10 feet if I take the screening can off...... :)
mrkelso
NNJ
#10
