Anyone know these radio codes?
N7DRT
Hurricane, UT
#1
Some of the LE agencies in Washington county, use the code of 54-10 or 54-11 as the final disposition of traffic stops. I'm guessing that this indicates where a citation has been issued, or it has just been a "yell stop." I'm wondering which is which, and also where these two codes come from. Can't seem to find anything on them.
Salt Lake County
#4
They’re actually cutting the code short.
The full code is 5499-10 which is a commercial vehicle inspection and 5499-11 which is fleeing.
Agencies like SLCPD and UPD clear every call with these codes, but it’s often done over the MDT
There are hundreds of them.
