Anyone monitoring Tollway ISP D-15?
nick223
Ottawa Illinois
#1
Just curious what tower site people are listening to ISP D-15 on and if anyone is around me that is picking them up around the LaSalle County area or close to the county.
Utica, IL
#3
You'll hear D15 and the ISTHA maintenance people on towers from Whiteside County up to Winnebago County and pretty much every tower in between there and Chicago :)
Depending on conditions, sometimes the units on I-88 will affiliate with T131 in LaSalle and T134 in Ottawa. You'll also catch D15 units affiliate on those towers as they travel to and from Springfield.
Clinton Iowa
#4
IDOT is losing their minds this morning !
Pretty lively listening on the IDOT talkgroups since they started battling our first storm of the season ! :)
IL
#6
Kane County and Dekalb County Starcom21 SITES should have them too. I listen to them on those when out that way. When coming north on rt39 earlier this summer in July, I was hearing D-15 on the LEE county tower 105 Starcom21 SITE as I was several miles south of rt 88. That's still at stretch trying to get 800mhz or 700mhz frequencies from where you are. Maybe a high tower with a high gain 700/800mhz Yagi would get those sites. OR, just listen to the feeds on broadcastify ;0)
nick223
Ottawa Illinois
#7
We have our antenna 65ft up on the tower and it picks up 700-800 pretty well. I have a Uniden 996p2 monitoring all the sites because I was new to starcom when I first programmed the scanner haha. So I want to cut down on sites so it will scan better. I do broadcast a feed for Broadcastify locally for ISP districts 17,5,1,2 off the Ottawa site and recent 6 and 8 seemed to be pretty steady on the Ottawa site now. But 15 not so much.
ILL
#8
I use here in the Joliet area T113, 102 and 126, all D-15 traffic....T102 has almost all the D-1 IDOT activity....Are TG's2002 and 2007 help trucks yet they run license plates....How about TG's 9098, and 9099 are they TW police like D2 and D5 cars....TY
ILL
#10
I monitor T125 in Morris/Grundy, its a good tower because calls from different TG's are limited meaning its not as busy as the Chicago area tower mess...I like listening to rural ILL there is a lot of action from Pontiac etc...I did find D-5 from 9pm till 6 am are now dispatched from D-6=Pontiac then D-15=CGO very interesting....Sometimes calls on D-5=Joliet that come thru T113=Will Co do not come thru T125=Morris, must be location of mobiles...This Starcom is a trickey situation to monitor....Also you hear Liv-Com TG's 57xx on T125 and IDot KankakeeYard and Morris/Yorkville yard now in the winter....
FFPM571
Chicago area
#11
HELP trucks only run plates before leaving the truck to make sure the vehicle is not stolen or the driver is wanted.If it does come back as 10-99 The HELP drivers are instructed to leave and the ISP is alerted to the location. No personal info is given to the HELP drivers.
