Just curious if there is anything else I can try out that might be better than SDRTrunk?
define 'better'?Just curious if there is anything else I can try out that might be better than SDRTrunk?
I'm using SDRTrunk 0.5.0 on Linux and only restart the program when either my system has patches that require a reboot, or SDRTrunk is patched itself. Otherwise, it hums along. It is using 5-7% CPU for a two site P25 on an Intel 12th gen i7-12700.Right now I'm pretty torn between setting up SDRTrunk or trunk-recorder...
SDRTrunk has a very nice graphical interface as well as some good features, but I'm concerned about it's stability and it's resource usage... I don't want to have to restart the application every few days, and I'm worried that even with a nicely spec'd machine, it's going to struggle with recording two very busy P25 sites.
My only real concern with trunk-recorder is how to deal with duplicate transmissions coming from both sites. Aside from that, I expect it to be very stable and considerably less resource-hungry than SDRTrunk.
I'm leaning heavily toward trunk-recorder... But honestly I'll probably end up trying both to see what ends up working better for me. If SDRTrunk is able to handle both sites, and can run for months at a time without crashing, then that might end up being the winner.
For anyone who has used both: I'd love to hear your experiences/comparisons between the two.
I'm not sure what "not foss" means, but I'm currently running Unitrunker 2.1 with 5 sdrs. Other users have more running.I've had pretty good luck with Unitrunker v2 and op25. The main downsides with Unitrunker v2 are (at least to the best of my knowledge) it's for windows, not foss, and only runs with one sdr.
How about an actual scannerJust curious if there is anything else I can try out that might be better than SDRTrunk?
V2.0 was not limited to one SDR.My bad, I need to update then, I think I'm still running v2.0.
foss is free / open source software, while Unitrunker is free, too the best of my knowledge it's not open source.
Not critical to the conversation here but some history - Unitrunker Version 0 "Retro" (vintage 2005) supported up to two radios - one for control and one for voice. Version 1, Version 2 and now Version 2.1 have all supported multiple SDRs.My bad, I need to update then, I think I'm still running v2.0.
SDRTrunk is designed to decode P25 trunking systems primarily. An analog conventional capability was added later as a convenience. Most people have multiple receivers / software packages to monitor multiple modes, but perhaps a traditional scanner would work best for you. The SDS series (and others) can record audio.
