Anytone Anytone AT-D868UV on RAS
K2NEC
So I heard some rumors that the Anytone will work on RAS systems with no problem as long as you use Digi Moni. Can anyone confirm or deny this?
w2xab
Sevierville TN
It may be able to monitor the traffic, but it will not be able to access the repeater.
The traffic is NOT encrypted by RAS, it just embeds an encrypted access code for the repeater which can cause issues decoding.
K2NEC
I am trying to monitor a RAS public safety repeater which I can't do with any portable and I heard that it was possible. As long as it decodes the audio then it's what I need.
jcardani
Orlando, FL & Ocean City, NJ
The reason why 2-way radios don't work on RAS enabled systems is because they read the checksum data and compare it with its calculated value. Since RAS modifies the checksum value, the 2 values don't match and the frame is discarded, therefore the audio will never un-mute.
I believe the DMR capable scanners and DSD Plus do not use the checksum to validate the incoming audio.
K2NEC
I am aware. I heard the Anytone doesn't check that which is why I figured I would ask before I spend $120 on a radio
