Anytone Anytone d868uv
9Z4S
Trinidad, West Indies
I recently acquired an Anytone D868 UV and while trying to program it the screen came up saying "WELCOME DMR and Analog Radio", I can't get in or out of it as everything is locked. Is there a way to do a factory reset. I cant seem to find any information on line. Thank you.
KE5MC
Lewisville, TX
Copy and paste from one of the update packages.
Power off the radio firstly. Then power it on while holding the PTT and
the PF1 button below the PTT at the same time. The radio will start up​
with a note on the display stating “MCU Reset”.​
*** Please Wait – and do not turn the radio off while it restarts ***​
After the MCU reboot, you will have to set the time and date.​
Use the P1 key to scroll through the date / time fields.​
Up and Down arrow keys will allow you to change the information in​
these fields. After you have the information entered use the Green key​
to confirm the settings.
56FB666
Bear Caretaker
dmaria
This has absolutely nothing to do with not getting past the boot-up screen.
dmaria
Definitely try this first.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
This issue probably relates to the recent change by Anytone that all new radios would be shipped with the keyboard locked (per FCC rules). Here is a video from Bridgecom Systems that explains how to unlock the keyboard...
9Z4S
Having pressed both ptt and F1 keys it is asking if I want to initialize radio, no MCU reset. Thanks for the help but I think I have had enough headache from one radio.
dmaria
His problem is getting out of the boot screen... No keys needed for that. After the boot up, it should go automatically to the vfo or memory channel. Again, no keys need to be pressed.
dmaria
That IS the MCU reset.....
KD8DVR
Columbus, Ohio
If you cannot get past the start screen, your radio has suffered catastrophic system failure. It will need to be replaced.
Sent from my SAMSUNG-SM-G920A using Tapatalk
TailGator911
Silent Key/KF4ANC
Fairborn, OH
I don't know the actual radio, but all computerized devices apply here - remove the battery for a few minutes, then replace and try again. If your radio continues to be stuck on the welcome screen, I'd say a repair call is in order. Call their customer service dept first and foremost. Might be something simple and overlooked. When in doubt, reboot.
JD
kf4anc
9Z4S
Thanks but shipping from Trinidad, West Indies is a bit costly and lots of red tape. I would have to apply to TATT in order to bring it back in so I wont be charged any taxes. Maybe I should just buy a different brand.
