https://readymaderesources.com/prod...mateur-ham-commercial-portable-two-way-radio/
Surprised to see it back. Good radio, the dedicated gmrs mirs mode, always had to look up in the book how to go to that mode. Just as easy to program in a channels, then assign a group and select the group or deselect it at will. The radio kind of flew in under the radar as it does cover alot of spectrum. It doesn't transmit everywhere but it does receive a pretty large spectrum. The other day someone was asking about a ht that covered cb, this one does. 2-30 mhz am. For ham vhf and uhf, great radio. Had mine for awhile, and I have had no problems. Audio is loud, 1 watt speaker. Like many Chinese radios, it plays fm 88-108 music while you monitor whatever on the vhf/uhf spectrum. Audio is much better than other Chinese radios I have worked with. Only short coming that I have found, I would like to have a bigger battery but one is not available. Tech support through Anytone Tech has been prompt. Email in the evening and most times, answer back a few hours later. Had no quality control issues. So any specs that are crossed off, should not hender operation of the radio as they are other ways to work the radio.
