AOR DV1 Antennas
thecop
Wilmington, NC
#1
Hello,
I was wondering how owners change the antennas for different bands on the DV1. Does anyone use the AOR AS5000 and if you do, does it work well?
I’m looking for a solution so I can monitor VHF/UHF/HF without physically changing the antenna or using an antenna switch. I do have an SA7000 but I can’t get it high enough for it to be effective. I also have a Welbrook Loop for LF/HF.
Thank you.
John
