APX “Legacy software system key” flash
Ant9270
The Green Weenie
Do you need Legacy System Software Key enabled in your flashcode to alter settings or import a key to edit a Smartzone system? I’m having a moment. I’m looking at a radio with “smartzone system operations” enabled, but it does NOT have legacy software key.
GTR8000
NY/NJ Database Guy
BEE00
A trunking capable APX is going to have either QA01648 ASK Enable or QA01749 Legacy SW System Key Enable in the FLASHcode. If the radio has neither option, then it's pretty likely someone was screwing around with software they shouldn't have been.
If the radio has SW Key enabled, you can use either a software key or an ASK. If the radio has ASK enabled, you can only change some system parameters with an ASK, the software key will not work.
Ant9270
The Green Weenie
I figured. Very odd flashcode on this particular radio I’m looking at. Looks like someone played with a certain tool indeed.
4
D1 B1​
Q806
Q806 ASTRO IMBE Digital Operation
D1 B4​
G996
G996 Over the Air Provisioning
D2 B3​
H869
H869 Hardware Multikey Encryption
D3 B4​
QA00572
QA00572 Primary Band: UHF Range 2
D4 B2​
QA00574
QA00574 Secondary Band: VHF
D5 B1​
QA00579
QA00579 Enable Dual Band Operation
D6 B4​
H38
H38 SmartZone Systems Operation
D8 B1​
QA00782
QA00782 Enable GPS Operation
D9 B1​
Q947
Q947 APCO Packet Data Interface
D10 B3​
Q173
Q173 SmartZone Omnilink MultiZone Operation
D11 B1​
QA00580
QA00580 Enable TDMA Operation
D11 B4​
Q361
Q361 ASTRO 25 9600 Baud Trunking
GTR8000
NY/NJ Database Guy
BEE00
Without QA01749 Legacy SW System Key Enable in the flash, you won't be able to make changes to any of the critical trunked system parameters.
navymrh90
Sydney, New South wales
So to say, having QA01749 Legacy SW System Key Enable is the more flexible option out of the two?
GTR8000
NY/NJ Database Guy
BEE00
Thanks! On an APX8000, does the option QA01749 Legacy SW System Key Enable need to be added as an option to the flash-code or is it already included by default? Trying to make sure that flash-code is valid with Motorola.
akardam
The flashcode includes the option "QA00579 Enable Dual Band Operation", which would indicate an APX7000 or 7000XE, the only two platforms that particular option is valid for. When APX radios first started shipping, there was no discrete soft or hard key options, they all required hard keys, period.
This is indicative of an early-manufacture APX7000, not a whoreflash.
