APX 4000 portable programming
Beaver state
#1
when i go the read APX 4000 radio,my lab top says it doesn't recognize the radio. Is there a step i'm missing or issue with the programming cable?
#2
A driver issue maybe? Reinstall the drivers for the usb cable. Had it happen to me on one computer in windows 10 professional while the other running enterprise 10 had no issue. Are you using the correct cps?
car5le
Northwestern Montana
#3
Just so I'm clear, you can connect the radio to your laptop and you have the version (or later version) of CPS the radio was last programmed with? What is the exact error message you get?
Beaver state
#4
I'm using software R13.00 that is newer then what was used to program the radio before. I'm thinking it a driver issue to. the error message says it cant connect to the radio. But with the same cable and same lab top i can read and program ApX 7000 radio's.
Colorado
#6
Which programming cable are you using? From the APX4000 User Guide:
"Note: Only the following programming cables are compatible with the (APX 4000) radios.
• APX DMR Port Programming Cable (PMKN4012B)
• Test and Alignment Programming Cable (PMKN4013C)"
I currently use PMKN4012A for 6000's and 7000's and keep the 'B' in a file drawer for when a 4000 surfaces.
R/MR
Beaver state
#7
I don't recall the model of the programming cable ,but i will check. Its used with APX 7000 model and works great, no issues.Looking at 4012A and B cables they both say they work with APX 4000?
#8
Have you tried another machine with your cps and cable? I had a similiar issue with a pc in which it was upgraded from windows 8 to 10 and even though I used the dvd with the drivers for some reason some missed. I had to reinstall the usb drivers for the machine. Have you tried saving all your codeplug back them up somewhere and uninstall then reinstall cps?
#10
MatRat has it right!
You must use the revision B cable to program the APX4000.
The reason is there is no external antenna connector (for PSM) style mic on the APX4000.
The Revision A cable used this external antenna connection for ground. (The 3 horizontal contacts above the main accessory contacts.)
The Revision B cable will work on all APX series radios 7000, 6000, 8000, 4000 etc.... And I imagine all TRBO radios also.
Has nothing to do with the driver.
#12
Do you know where i can get PMKN4012B cable? all the cables i found say PMKN4012B but have the 3 horizontal contacts?
The B version WILL have the 3 contacts for cross compatibility. It will still work, the B version just picks a ground up from a different pin location for compatibility with the APX4000.
There are many B version cables available on the internet from dealers or MOL. In fact the A version is NLA from Motorola and has been replaced by the B version.
