APX 4000 programming cable
Atlanta GA
#1
Are the APX series of programming cables all the same? EXAMPLE: If I had an APX 7000 programming cable would it work on an APX 4000? Yes, I know many of them do Bluetooth. Thanks for any information you can provide!
Mississauga Ontario
#2
Yes. The cable is the same. The part number is PMKN4012.
See page 50 on the attached link https://www.motorolasolutions.com/c...sories/_documents/apx_accessories_catalog.pdf
Pro-91, MTS 2000 800MHz, Astro Saber VHF, APX 6000 7/800MHz
#3
"Note: Only the following programming cables are compatible with the (APX 4000) radios.
• APX DMR Port Programming Cable (PMKN4012B)
• Test and Alignment Programming Cable (PMKN4013C)"
dpcain
MD
#5
In general, just avoid the PMKN4012A. Go for the B/C whenever possible. The /A has been known to brick things very unproductively in rare cases- we threw ours away for that reason.
