motorola2935
- Joined
- Jul 21, 2016
- Messages
- 27
I have successfully gotten an APX6000 to monitor my statewide 700/800MHz P25 Phase I/Phase II dynamic system. I had used the radio prior on the Phase I but these days more and more talk groups every day are heading Phase II. The radio worked great on the Phase I/FDMA talk groups the way I had it setup without the correct WACN. When I decided to retry TDMA I found out my WACN was not correct on my trunking system tab. I fixed that but when I fixed that TDMA worked! But I ran into an issue, when scanning any of my scan list from a conventional channel to trunking talk groups any scan list that had my new populated TDMA talk groups in them seemed to be very slow on scanning talk groups for TDMA and FDMA. I was missing whole 15-20 second dispatches on FDMA talk groups and on TDMA I was missing between 10-15 seconds of the transmissions. I compared it to my XTS-5000 running complete FDMA talk groups and it was pickup everything perfectly with no issues, so I'm not very sure what is causing this issue of slow scanning when the WACN got set correct. To troubleshoot I set the WACN to something random again then scanning went back to being perfect, not missing a transmission or even a millisecond of a transmission but then the issue of TDMA talk groups not working at all when the WACN is set correct (it goes into the wonderful issue of not unmuting or showing a RID on the screen). So I'm not very sure whats going on with it and if this is maybe just a common issue. The radio was purchased brand new from local motorola 3-4 months ago. Since then just to ensure it was perfect they have retuned it to factory so I know for sure thats not the issue, the channel band plans are all correct. Also my scan list are only setup with 4-5 talk groups in each one so its definitely not over population. Any help with this is greatly appreciated!
