APX APX 6000 Bluetooth Connection
TexScan780D
I got this Motorola APX 6000. The Bluetooth connection seems to be picky in connection with devices. Any known Bluetooth speaker or Bluetooth headphones would work with the radio Bluetooth?
K2NEC
5F6
Yep, search box still works...
TexScan780D
I am hearing impaired which I need hearing aids. The radio tech tried to pair my hearing aids to the APX 6000 but did not work. I am unable to understand majority of the radio traffic coming from the small radio speaker. Therefore, I am looking for headset that would go over my hearing aids or even a larger speaker which might help me. Thank you for the reply, but I see that thread was not helpful.
PARTHCITY
I haven't used hearing aids so I don't know how much they extend past your ear. A good option for this would be to use your hearing aids and then use the Mission Critical Bluetooth Pod. PN NTN2570. This item is a small BT pod with a small earpiece that floats over your ear. It does not go into your ear canal. The earpiece sits very close to your ear canal so the hearing aid should pick it up very well.
Another option could be the Mission Critical wireless RSM. You could wear it high up on your shirt near your shoulder.
OnYourSix
You can try an aftermarket adapter like Pryme. Or upgrade to an APX N70 that allows aftermarket bluetooth connections. Or switch to a Unication G5.
n3obl
ØAES-1024
PA
Have you tried the wireless speaker mic. I use hearing aids and that mic I can place near my ear without cords is nice.
TexScan780D
No I haven’t. I heard at least 2 mention the wireless speaker mic sound quality was not that great. It was mentioned that the speaker mic has an output that can be connected to the vehicle sound system, I thought that was cool. I just might see if the radio tech would let me test one out.
TexScan780D
maybe I am looking at the wrong item because I don’t see how fitting over the ear.
PARTHCITY
Try this link. There should be a photo of a police officer wearing the item. It is kind of hard to see but its a clear tube that floats inside the ear.
mikegilbert
MHz so good
Los Angeles
I picked this earpiece up a few months back. Pairs with my APX8000 with no issues. You can't adjust the volume, but I found it a-okay for most situations.
You'll need 2 things:
  1. Standard Pairing checkbox checked in CPS
  2. BT menu option enabled in CPS
MatRat80109
Colorado
We have a user with an HR validated ADA requirement for hearing aids. Our standard templates already includes the BT menu entry as the Motorola BT microphones seem to be springing up all over. In Radio Wide > Bluetooth we enabled Standard Pairing for just this radio. From there it was up to their audiologist to iron out the hearing aids pairing with the radio.
