APX 6500 not scanning anymore
Colorado
#1
Hello,
My agency uses the APX 6500 P25 with the 05 control head in our new vehicles. At one point in time our radios would scan channels in our "scan list." Presently, we are unable to scan, even while our older Motorola Astro radios are able to scan the channels in our scan lists. I have followed the directions in the user manual to re-program the scan list, but to no avail.
Just curious if anyone else has experienced this problem.
Thanks!
So Cali
#2
Is SCAN enabled in the radio? May be SCAN was disabled in the radio with a 'programming up date'.
What happens when you hold the SCAN button down, it should beep?
RKG
#4
It could be that the Mike hang up function isn't working. Either restore the Mike hang up function or program the radio for "off hook scan.". I normally don't recommend the latter for line radios.
