APX 7500 Mid Power 03CH
Outerbanks4wd
Woodbridge VA
APX 7500 Mid Power(Dual Band)Remote Mount 03 Control Head
Is speaker connection available at the trapezoidal connection on the back of the radio, in remote mount 03 CH configuration? (pins 26 and 20)
What tells the brick to turn off audio spkr out here, at the rear trapezoidal connection, when using the 03 CH? Why must I go to the front and use the 25 pin ( front accessory cable)?
Thank You,
