APX 8500 Base Station Antenna
estone4009
Philpot, KY
I have an APX 8500 base station that needs a 700/800 antenna. This is the only band currently in use. Can anyone recommend a simple indoor antenna setup to try as mouting.an antenna outdoors will be problamatic? Singal strength inside rhe building is decent.
estone4009
Philpot, KY
Trucked system and only transmitting a couple times a week. I will have to look into the transmit power options.
At work, in this sorts of applications, I just have them use a standard 800MHz 1/4 wave whip on a mag mount. That would get stuck on a file cabinet or window sill. Keep the power low if you do programming. Or, just make sure it's spaced away from the user.
This antenna:
This mount:
N4KVE
PALM BEACH, FLORIDA
I used to deliver cars to the HUGE car rental return building across from the Miami Airport. Basically a 4 story parking garage, in the office they had a radio on the counter with a magnetic antenna sitting on the radio. I had to laugh.
I had to laugh.
It drives the radio guy inside me nuts, but it works.
I -really- want to do an external antenna, but the cost/effort is beyond what they want to spend. Usually these installs are places where a portable works fine, but battery charging/replacement becomes more costly than just doing a mobile with a power supply.
