APX BT with Remote Speaker Mic
GeoFenceFound
Guthrie, OK
Our APX7000’s here at work have BT enabled but they did not add the BT under the menu items so you cant see if something is paired/ connected, ect. Can the Motorola BT RSM still be able to connect to the radio?
lskipper
SUMTER
Need to have BT option added to the menu to work with WRSM. Plus there are settings in the radio that need to be set so the WRSM will work properly
Sent from my iPad using Tapatalk
lskipper
SUMTER
I would change the Bluetooth Re-Pair to infinite. That way it will automatically connect each time you have both radio and WRSM turned on.
Additionally, changed the friendly name to the serial number of the radio. That way p, if you are programming via Bluetooth connection, you can tell which radio you are connecting to. If they are all the same then you might see a lot of “APX RADIO” to try and connect to. It works works for us. Your mileage may vary.
GeoFenceFound
Guthrie, OK
I have tried programming via BT but for some reason I cannot get any radio to connect to any computer. It will connect to my phone. I was kind of hoping it would work with my LG Tone headset for some more discreet listening but no go.
lskipper
SUMTER
It would be a lot easier if you had the BT option available. Then you could see what device you are attempting to pair it to.
GeoFenceFound
Guthrie, OK
It is avaible. I scroll over and select BT and all my options are there. Im just not sure why it would connect to my phone but nothing else. It better connect to the wireless mic. (We dont have the mics yet)
121gigawatts
As a APX programmer, you need to add the feature with the APX CPS program under the menu tab. Otherwise, it is impossible to pair your device, even if the BT option is enabled.
Sent from my SM-G930V using Tapatalk
