APX APX Conventional MDC Programming Question
mikey224
Cant seem to figure this out, in the APX CPS I have a Conventional MDC System set up. All Conventional Personalities are set up with the MDC System and Channels with the correct PL/DPL Codes. In Conventional Personality Under Non-Astro Signalling if "MDC" is Selected the radio does not allow the transmission to be heard, the RX led flashes and if the "MON" button is pressed the transmission is heard. Now if Non-Astro Signalling is set to ''NONE" the transmission will be heard. According to the Help File it should be set to MDC. Never have had this issue with any other radio model. Also with ''DOS" enabled, why I am I still hearing the Pre-MDC Squawk on received transmissions?
K2NEC
5F6
Your signalling should be set to disabled. If you have it set to MDC, that means the radio is going to look for the MDC, and it won't un-mute until it finds it. Same thing with Quick Call. The channel won't un-mute if it's set to QC.
With DOS it depends what your settings are. I keep mine at 1200/1800 Hz and Coast time 275 and it sounds nice. If you don't want to hear the ID at all, you can change those settings to your liking.
ElevatorsAndRadios
yarewesog
SoCal
Are you sure? My guess would be that he has selective call decode turned on. Maybe the radio is looking for a selective call and won't unmute until it receives one. Try turning off selective call decode. That fixed the problem for me while allowing me to leave MDC on, albeit on an XTS 5000 haha
K2NEC
5F6
Now that you mention it, I'm not sure. A screenshot from OPs signaling tab would be awesome.
Forts
Ontario, Canada
I just took a look at my APX... I have MDC setup on our fire channels and don't have any issues receiving general transmissions.
Under Rx Options - Voice is Non-ASTRO, Unmute / Mute Type is UnMute, Or Mute
Under Signalling - Non-ASTRO - Type is MDC, Proper system is selected under System Number and PTT ID is checked
Under Non-ASTRO Call - Sel Call & Call Alert are disabled. MDC is set to None.
K2NEC
5F6
Same here
mikey224
That did it Fellas, my Selective Call was set to Decode, Disabled it and now the "DOS" is working correctly along with MDC enabled in the Personality Tab. Thank You for the assistance.
cablemonkey
I just ran into this; you need to set Selective Call unmute type to OR. CPS sets it to AND when you enable selcall decode.
Unmute Type (Conventional Personality, Non-ASTRO Call)
AndBoth the current personality’s selected Unmute / Mute Type rule, and Selective Call detection must be satisfied before unmute occurs.
OrEither the current personality’s selected Unmute / Mute Type rule, or Selective Call detection will unmute the radio's speaker to receive audio.
