APX APX Migration Assistant
bunnycop
Altoona,Pa
Hello, I know the rules about asking for CPS, but is the APX Migration assistant considered in the same classification? if not, how can I get a copy of it? I just ordered the CPS from MOTO and wasn't sure if the Migration assistant was included in the CPS or if it was a separate program. Thank you
GTR8000
NY/NJ Database Guy
BEE00
It's a separate program from the APX CPS, but once you have a CPS subscription, you should have access to APX Migration Assistant R14.00.00 in the same location on MOL where you download the APX CPS.
MatRat80109
Colorado
It's been a while since I had an actual disk but I do not recall M.A. or Tuner being on the CPS disk.
For MOL:
  1. Go to Motorola Online Login and login using your MOL credentials.
  2. Open Resource Center at the top Left and select Resource Center from the drop down list.
  3. Expand Software in the left frame, then Two Way, and click on APD Family Portables and Mobiles.
  4. In the right hand frame you should find APX Migration Assistant at the current R14.00.00 level. Click to download the zip file.
  5. It will take Motorola Customer Care if any of the above steps are not available or do not work.
My MyView page is being configured so I don't know if it is available there.
R/MR
