APX Mobile Antenna Connector and Crimp Tool
Okay I’m sure it’s on here but I can’t find it on mobile.... What connector are the APX series mobiles (4500/6500/7500/8500) using? UHF Mini...? I’m looking to get the proper crimpers but there seems to be so many choices for so many versions of the UHF Mini connectors. Any advice?
GTR8000
NY/NJ Database Guy
BEE00
4500/6500/7500 use Mini-UHF, the 8500 uses a QMA (quick-connect SMA)
P25Radio
Oceanside Ca.
Mini UHF connectors. Some crimpers come with a set of dies. Also they have instruction on which die set to use for what type of connector you use.
Hop763
Ky
On the QMA connectors the center pin normally needs soldered and the outer can be crimped with the tool. You would need to know what cable you have to match it to the dye size.
