APX PL question
Beaver state
#1
I have PL code on receive on many of my channels and looking at the radio those channels show a speaker which means the receive is CSQ. what setting do I need to change to turn off Carrier Squelch?
thank you
N1GTL
CT
#3
The radio is looking for the mic to be grounded. When you take it out of the clip, it goes into monitor.
Under CONVENTIONAL WIDE, uncheck the "HUB defeats PL" check box.
sfd119
#4
If it's a mobile...
OP: What APX do you have?
