APX PL question
Baker845
anywhere
I have PL code on receive on many of my channels and looking at the radio those channels show a speaker which means the receive is CSQ. what setting do I need to change to turn off Carrier Squelch?
thank you
sfd119
If you have PL tones on the channel, Monitor mode is enabled.
N1GTL
CT
The radio is looking for the mic to be grounded. When you take it out of the clip, it goes into monitor.
Under CONVENTIONAL WIDE, uncheck the "HUB defeats PL" check box.
sfd119
If it's a mobile...
OP: What APX do you have?
cmdrwill
So Cali
What was it?
You has to check the little boxes in the programming to have one of the buttons do MONITOR. IIRC there are three different settings. Who in his or her right mind would write this crappy programming software!
