APX unified call list export?
#1
Is there a way to export a unified call list out of CPS? I see instructions to IMPORT but nothing to EXPORT. What I'm trying to do is edit about 15 or so entries in this call list and then import it into about 40 radios
mikewazowski
Staff member
Central Ontario
#3
Click on the Motorola icon in the top left and select Export.
You can select Unified Call List which will dump an xml file containing your records.
mikewazowski
Staff member
Central Ontario
#5
Let me know if you find a good xml editor.
You can open the file in notepad but when you've got a lot of records, it's not always easy to find something.
#6
I actually did my edits before I exported. I then imported it into the other codeplugs. Now I just have to rewrite em into the radios and they're all set.
