APX4500 Programming
Kanada2022
Good day peoples.
New guy here wanting to reprogram a radio model number M22URS9W1AN with flash code 001048-G01400-1. No issues reading or writing to radio. It has an analogue trunking system programmed in it and want to delete the system and program with p25 conventional only channels. Can these radios be programmed with conventional only channels or must a trunking system remain. Unable to delete the existing personalities.
Thank you for any help with this.
Rich
GTR8000
NY/NJ Database Guy
BEE00
You may not be able to delete any of the trunking systems/personalities without the system key. You can try to create a new trunking system, then delete the existing one. Do the same for the trunking personalities, create new, delete the others. CPS requires at least one of each system/personality to remain, you can't delete everything.
Worst case, just leave them be and delete all of the zones/channels/scan lists that have any reference to the system. You may wind up with some invalid fields after doing so, which you'll have to clean up.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
That's an analog only radio:
Decoding Flashcode: 001048-G01400-1 Platform: APX 4500
GA00244 - 7/800 MHz Band
QA01749 - Legacy SW System Key Enable
G51 - SmartZone Operation
G193 - Advanced Digital Privacy
W947 - APCO Packet Data
G173 - SmartZone Omnilink MultiZone Operation
6 options included in this flashcode.
Decoded with CS Forums Flashcode Decoder
Thunderknight
Bletchley Park
That looks to be a weird flash?...has APCO packet data and ADP but not Astro Digital...
GTR8000
NY/NJ Database Guy
BEE00
Pretty much every APX comes with Packet Data now, and as for ADP, you have to specify whether you want the radio to be P25 CAP (AES) or not, and if you might use ADP at some point in the future, you have to specify it when ordering.
Kanada2022
Thank you all for the quick replies. I will try the add and delete first then upgrade to digital if I get past the first part . thanks again
Rich
KevinC
The big K
Super Moderator
1 point
But as we all know, you can’t actually remove SW ADP from any APX. If you order it with no encryption it’s just sets a flag in the code plug that won’t let you chose any encryption (be it HW or SW). ;)
